My oil tank is leaking where the fitting is at the bottom. IS this something that can be tightened without draining the tank. It isn't a lot, but it is making a mess out of my bildge. I had to clean the water sensor because it was coated with oil.
Rob
Oil Tank leak
Started by Robmoo, Aug 28 2005 09:30 PM
Posted 28 August 2005 - 09:30 PM
Posted 29 August 2005 - 08:54 AM
I'm pretty sure the fitting is supposed to just fit snugly in the rubber grommet at the bottom of the tank, so tightening is not an option. I don't know if you have ever had the tank out ( I have), but it isn't the easiest thing in the world to do. I would replace the grommet personally.My oil tank is leaking where the fitting is at the bottom. IS this something that can be tightened without draining the tank. It isn't a lot, but it is making a mess out of my bildge. I had to clean the water sensor because it was coated with oil.
Rob
