Man this is MUCH better, Aux input for my iPod (using RCA cables via Aux In, not that useless Clarion iPod interface), Remote LCD unit mounted just in front of the throttle so the driver can FINALLY operate the radio!
The operation of the remote is great, you have basically full control of the deck including source selection. It also displays whatever the main screen is showing, including the screen saver! I have my M455 set to display a message instead of screen saver and sure enough, it shows up on the remote scrolling across. You can also have the deck and remote show the clock on idle, finally eh, a clock!
One thing that is annoying about the deck however is the backlight is always on, the old Clarion had an Illumination lead. However, you'll notice on the SCIC wiring harness that BRP did not wire this lead... figures eh. Pretty simply to just tee it into one of the blue dash gauge wires that are only about 4 inches away.
I'll tell you... it was SCARY cutting that 3 inch hole in the hull!!!!!! But it all fits good (a little white Silicone II to make the remote perfectly flush since the damn boat doesn't have a flat surface anywhere...).
The M455 just slipped right into the old Clarion's bracket, same wiring harness, same everything. Had the new deck installed in about 2 seconds!
Pics are in the gallery, here are the shots:
![Posted Image](http://seadoosportboats.com/cpg/albums/userpics/10630/normal_3%20inch%20hole%20cut.jpg)
![Posted Image](http://seadoosportboats.com/cpg/albums/userpics/10630/normal_3%20inch%20hole%20zoomed.jpg)
![Posted Image](http://seadoosportboats.com/cpg/albums/userpics/10630/normal_Console%20complete%20and%20Lit.jpg)
![Posted Image](http://seadoosportboats.com/cpg/albums/userpics/10630/normal_Remote%20and%20GPS%20Lighted.jpg)
![Posted Image](http://seadoosportboats.com/cpg/albums/userpics/10630/normal_Remote%20Up%20Close.jpg)
For the full size images, click below (warning LARGE images):
http://seadoosportbo.....0hole cut.jpg
http://seadoosportbo.....le zoomed.jpg
http://seadoosportbo.....20and Lit.jpg
http://seadoosportbo.....S Lighted.jpg
http://seadoosportbo.....0Up Close.jpg
I'll update more once I have a chance...
Take Care
Tim
