Out on the jet ski down oxwich bay. The 1997 XP was a marked departure from the previous models. An all new hull specific to the XP was developed which brought a "lean in" style of riding to the craft. Further enhancing this was Sea-Doo's "Direct Action Suspension," a raised seat that was mounted on a pivot and had a shock absorber at the opposite end. The 110HP 782cc engine was carried over, as was the predominantly yellow with black accents color scheme.3 The 1997 boat was over 90 lbs heavier than the 1996 boat, which resulted in slower acceleraion from the previous year although realizing a top speed gain by about 1 mph. Nonetheless, the riding experience was enough for the XP to win WaterCraft World's Watercraft of the Year award in 1997.4 For 1998, the power to weight issue was solved by the new XP Limited model. This craft was powered by a 951cc (called a Type 947 )engine with reed valves on the intake and RAVE valves on the exhaust. The new engine produced 130HP and pushed the 1998 XP to 60 mph. Graphically, the lower hull, cowling, and handle pole cover were now black, and the hood and cowling pod were metallic gray. The 1999 XP Limited mainly featured graphic changes, as the hull colorings remained unchanged from 1998. Many driveline upgrades were incorporated due to previous failures in the couplings. In 2000, colors were the main changes for the XP Limited, as the hull deck were changed to black; the seat and hood were silver; and the cowling, handle pole cover <b>...</b> | From:jonboxer Views:0 ![]() ![]() ![]() ![]() ![]() 0ratings | |
Time:07:00 | More inSports |
View the full article
