oil found on bilge plug
Posted 01 September 2004 - 12:24 PM
Posted 01 September 2004 - 01:03 PM
How much oil? if it's just a "sheen", chances are you won't find a leak. If it is very noticeable by more than a sheen, like floating on the bilge water, then you could probably find a leak somewhere. Start at the oil tank and work your way to the engines by following the lines.
Are you sure you have twin 720's?
Posted 01 September 2004 - 01:24 PM
hi tiggerman! thanks for your reply. i notice more of an accumulation of oil on the plug when i pull it out. it is like i dipped it in oil. i called the dealer regarding the problem and he said unless i have oil spewing out of the crank shaft, i should not worry about it too much but i should keep an eye on the oil level just in case. what does the 720 stand for after the twin 85hp rotax?Hi sunnyday and welcome!
Posted 01 September 2004 - 01:28 PM
The reason I ask is I was under the impression that the SK had twin 110 HP engines, not 85 HP..... Regardless of what the dealer says, I would still have a look and see if I could spot anything.
Posted 01 September 2004 - 01:39 PM
right on! i will definitely take your advice and trace the oil line to verify leak source for myself..The 720 is the cc capacity of the engine, which in this case is actually a 717....
another question...my fuel gauge does not work. what should i check first to see if i can get it working again? right now, the only way i know if i am low on fuel is the low fuel control beeps & flashes at me or i poke my nose in an take a visual look at the tank. is it costly to fix?
Posted 01 September 2004 - 01:50 PM
