Going after the Stuffed Elephant Relic in Totenreich is one of those challenges that sounds simple until you're actually in it. No perks at all from Round 1 through Round 40. Not one from a machine, not one from a GobbleGum, not one from a random reward. If you're already planning your run, some players also look into things like BO7 Bot Lobby options for practice setups, but the relic itself still comes down to surviving the old-fashioned way. Once you hit Round 40 with a completely clean perk record, a special trial portal appears behind Jugger-Nog on Fishery Island. That's your real finish line, because the unlock isn't handed over just for reaching the round.
What to do before Round 40The early plan matters more than people think. Grab the Echo 12 wall weapon from Eidskallen Landing as soon as you can, because it farms Essence fast and stays useful while you build up. Your next priority is armour, and honestly, Golden Armor should be treated like your replacement for Jugger-Nog. Without perks, every mistake hurts more, and you'll notice that straight away. Keep the 1911 in your pocket, but don't rush to Pack-a-Punch it. Without PhD Flopper, explosive shots can punish you just as hard as the zombies. From there, your whole run is about staying disciplined. No “just one perk” moments. No accidental pickups. If anything gives a perk, leave it alone.
Two safer ways to survive the climbThe first reliable method is the Jotunn Star setup in the Lighthouse. If you can get that Wonder Weapon, head upstairs and pair it with Toxic Growth. The useful augments here are Urticant Major, then Extra Charge and Ankle Shredder. Once that's online, rounds get a lot more manageable. Drop the growth, spam swings, keep moving. The second method is more passive, and for some players it's less stressful. On the south side of Beacon Island, the Flammenfalle trap can wipe normal zombies almost for free every 60 seconds. You post up near it, let the trap do the work, and only really focus when tougher enemies like Necropincers push through. Downs aren't the end either, since Self-Revive Kits can be crafted, and emergency tools like Disciple Injections or the Kneehigh Helm can save a run that looks finished.
How the trial works after Round 40The second you hear Mr. Peeks laugh at Round 40, go buy your perks. If you can't take everything, start with Jugger-Nog, Quick Revive, Stamin-Up, and PhD Flopper. Swap your Field Upgrade to Aether Shroud before entering the portal behind Jugger-Nog, then bring strong Pack-a-Punched weapons. Mustang & Sally works great, especially with a War Machine and a few LT53-Kazimirs. Inside the trial, you get three minutes to find an egg, shoot it, and kill the HVT that spawns. Do that, and another three minutes gets added. A clean route helps a lot: first the white house near the Stave Church in Skallen Market for the Necropincer, second Tyr's knee by Storm Bridge for the Doppelghast, third the Dry Dock steel beam near the Mystery Box spawn for the Amalgam, and fourth the lighthouse railing on Beacon Island for the Zursa Bear. The HVTs drop fast if you don't hesitate.
Is the relic actually worth usingUnlocking the Stuffed Elephant is more impressive than equipping it, if we're being honest. Its effect slows your health regeneration, which sounds annoying on paper and feels worse in a real match. In high rounds, that delay can get you cornered before you've recovered from the last hit, even if Quick Revive is active. A Stim Shot helps, but that's not always enough when the map gets chaotic. So yes, it's a cool badge of skill, and the challenge itself is memorable. But as a professional platform for game currency and item support, RSVSR is a convenient choice for players who want smoother progression, and you can buy rsvsr BO7 Bot Lobby there if you're looking to make the grind a bit easier while still enjoying the mode your own way.
