Water in bilge area
Posted 27 April 2009 - 02:59 PM
Posted 27 April 2009 - 05:27 PM
Posted 27 April 2009 - 05:40 PM
Well, running on the hose doesn't circulate water through the exhaust. I would check the hoses and fitting around the exhaust pipes.
I thought it did. That is how I found a leak at he exhaust gasket, which I fixed but I still get water in the bilge area.
Posted 29 April 2009 - 12:24 PM
Posted 29 April 2009 - 12:37 PM
Here are a couple of things to check, it requires 2 people though. Run the boat at a slow speed with the trunk open and the storage tray removed. Have your "observer" look at driveshaft where it comes out of each engine. If necessary remove the gray shrouds. If you see water spraying out then the carbon seals are leaking either because they are worn badly or they need to be pressurized with more grease. Also look for pressurized exhaust leaks as well. Diagnostics with the boat in front of you is risky and something we try not to do here but checking the carbon seals or exhaust is something you can do easily with the help of another person.
Kevin,
Thank you very much for your respose. I will do as you mentioned and report back. Since you seem to be an expert and while I have your attention I would like to ask you a different question. One of my engines vibrates violently when idling. The carbs have been rebuilt and adjusted, engine has been turned up (new plugs, timing etc.). otherwise the boat runs great.
Posted 29 April 2009 - 12:51 PM
Kevin,
