Please help diagnose speed loss on 1800
Posted 07 June 2006 - 12:26 PM
1997 Challenger 1800 - has been running like a top! - until yesterday
*speed #'s are according to speedometer not actual speeds
I'm cruising @ about 5k ---> 40mph* --->6k (50mph*) ----->7200k(60mph*)(WOT)
THEN - It feels like when a tranny slips on a car -and I can't get above 40mph* even at WOT!
Now I have to run @ 4k just to start moving!
Are my impellers - clogged? Broken? I'm at a loss here!
anyone bueller?
Posted 07 June 2006 - 12:32 PM
Posted 07 June 2006 - 04:18 PM
why does it feel like I'm talking to myself?!
I opened the grates and when I reach inside I can feel fishing line wrapped around the impeller(?) - could this be my problem?
How do I get the fishing line off?
Posted 07 June 2006 - 07:34 PM
Posted 08 June 2006 - 04:18 AM
impellers you should find that they will run ok
Posted 08 June 2006 - 09:51 AM
Posted 08 June 2006 - 12:14 PM
Yes...just remove the fishing line and inspect your pump. Make sure your impeller nose cone is on and not walking up the driveshaft and most importantly check your wear ring
Thanks for the tips!
I'll let you know how I make out!
Posted 08 June 2006 - 06:13 PM
what should I check next?
Posted 08 June 2006 - 07:38 PM
Posted 09 June 2006 - 06:31 PM
Maybe I should order evrything I might need ie. impellers.wear rings, new seals, bearings - before proceeding further. or maybe not!
ALSO - I was wondering if I would get this loss of speed if the reverse bucket isn't moving up and down properly.
Posted 09 June 2006 - 11:50 PM
In the attached picture, if you look down the pump passed the vanes you can see a light almost white coloured material. This is the Delrin wear ring that surrounds the impeller. This is on my 2005 C-180...and changing this out is not a big dea and yes...it just requires removing the reverse bucket, dis-connecting steering linkage and then removing pump. Removing the wear ring with the impeller in is a bit tricky but if you remove the impeller to repair or replace then the wear ring removal is easy. If you don't feel comfortable I would find a reputable dealer/mechanic to do it for you.
Hope this helps
Same thing only this is a Stainless Steel wear ring and is easier to see.
Posted 10 June 2006 - 11:09 AM
Posted 10 June 2006 - 01:03 PM
Wear Rings
#14
Posted 10 June 2006 - 02:55 PM
I had a window open to that site before I even read your post!
Good idea bringing a copy to my local dealer..
