Fuel Economy
Posted 13 August 2005 - 10:15 AM
Posted 16 August 2005 - 08:50 AM
hopefully somebody else will chime in with some figures for a twin speedster.
Posted 16 August 2005 - 01:38 PM
The twin 155's use 22GPH worse case (wide open, ~55MPH) and 10GPH at the most efficient crusing speed of 32MPH or so (as stated on BoatTest.com). I would expect the 185's go up from there.my 215 rotax burns about 8-10 litres an hour for skiing (30 ish mph)and thrashing around (60ish mph) so i guess if you double if for twin 185 and add a little say for the extra weight you would be close say 25 l/hr - maybe more????
I found it interesting that the 18' C-180 with the 215HP SCIC engine had almost exactly the economy numbers on BoatTest as the S200 with TWO 155HP engines on a 20' boat. This was at best crusing speed and WOT.
Steve
Posted 19 August 2005 - 10:02 AM
Posted 19 August 2005 - 01:53 PM
And that is what led me to ask, 'Did they test a new boat?' Not only was the fuel consumption relatively high, but top speed was low. Were they testing a boat that was still in the break-in period and running with a richer mixture and reduced rev limits?I found it interesting that the 18' C-180 with the 215HP SCIC engine had almost exactly the economy numbers on BoatTest as the S200 with TWO 155HP engines on a 20' boat. This was at best crusing speed and WOT.
Steve
My C180 runs significantly faster than shown in the tests(GPS verified) and compared to other boats, does not seem to be any sort of a gas guzzler.
Posted 23 August 2005 - 06:58 AM
