Hi Everyone,
I cant figure this one out...
Water is accumulating in the bilge at the rate of a half gallon per minute while running fast at high 6,500 rpm. I cannot see where it is coming from. However very little water comes in while running slow at lower rpm.
Everything looks to be in good shape. I'm not OK relying on the functioning bilge pump in order to use the boat.
Is it possible to use the flush fitting with garden hose pressure combined with some well placed clamps to leak check while on land? Is this a bad idea due to risk of flooding cylinders?
Ahy other ideas to consider or places to inspect would be greatly appreciated.
Best regards,
Scott
