95 Speedster Oil and Gas tanks leaking?!?!
Posted 28 June 2005 - 08:24 PM
I ran the engines for a few seconds and throttle revs to purge the systems and lazily stored the boat in a insulated garage throughout the Michigan winter.
Now that summer is here, I did a quick look in the engine compartment and it looked OK on first glance so I thought..let's see if it will crank!
But, the battery is dead! (2 batteries removed one battery replaced thanks to this forum!)
Anyways I put a charger on the battery as it would not crank and found that the bilge pump was on (even though the switch was positioned to off!)
Blue tinted Water started spewing from the boat!! Amsoil I presumed right away! ;(
So I got out the flashlight and noticed that the bilge on the starboard engine side is pooled with "some" oil.
I found that the oil tank is almost empty (about an inch of oil up the tank, but the hoses all have oil in them) and the gas tank is also almost empty...way below the "e". I remember that there was plenty of gas and oil in the tanks prior to forgetting about the boat for the winter!
Here are the questions:
1. How can I tell what/where the fluid(s) leak is?
2. Is the gas/oil tank/hose connection(s) leaking?
3. Is one of the engine seals bad and how can I confirm?
4. What would cause oil and gas to both leak out (if indeed they are leaking)?
5. Is it possible that the fluid only pooled to one-side because it is truly a leak affecting one side and the fluid just didn't flow to one side?
I am no mechanic, but I know the right answer when shown...most times!
Thanks in advance for any tips/tricks/how-tos/etc...
Posted 30 June 2005 - 12:25 PM
Regarding no fuel in tank - Were the fuel shutoff valves @ the driver's seat closed?
FYI:
The shop manual says to check for fuel leaks: Detach the vent hose from the right side of the boat and connect to 5 PSI air (no more). Use a soapy water solution to check for air bubbles (air leaks) in the hoses and connections.
Posted 01 July 2005 - 10:20 AM
Posted 02 July 2005 - 10:37 PM
First off, I am too much of a novice, and I must humbly admit that the "e" level indicator is not for the gas....but for the oil tank...it helps to read the manual now doesn't it....I known always RTFM!!!
I believe that the fuel shut off valves near the driver's seat were closed in storage, I am pretty sure that I turned them off when I put the tarp on it (even though it was stored inside...) the problem is that the prior owner must have removed the knobs because when in the correct position one knob indicates that it is facing the incorrect position...
I have placed the battery on charge and I hope that it will take because it will be a pain if I have to remove the big battery! I am actually a little scared to see if the engines will ever turn over.
I will pull the spark plugs just in case water in the cylinders on the first couple of tries...I should ground them correct...?!?!?
Regarding the the shop manual and how to check for fuel leaks, I looked every where for a tool that can be used to inject pressure into the fuel/oil lines to ensure that there is no leaks and to verify pressuirzation...
Where can I get a pressure pump/valve gauge? So far the only tools even close are for brake vacuum and radiator pressure...
I bought a bunch more Amsoil to refill the oil tank and hopes of seeing where it is leaking, but I do not want to waste any more oil or $$$ just to clean it up or pollute the lakes...I may have to rename my Doo to the "Exxon Valdiz" if I take it out (ever again) without finding the leak...I do not want to NOT find the leak!!
Keep the tips coming, I really appreciate your time and input!
Thanks in advance!
Posted 05 July 2005 - 08:46 PM
I think that the oil is accumulating directly under the motor mount plate first then seeping/dripping onto the bilge area…still not sure as to the source of the leak!
The hoses still have oil in them and the crank can be turned using my hands.
I still have not attempted to crank/start it with the plugs in or out.
I am hoping that most of you will stop chuckling and offer some more tips, I truly do appreciate your time and pointers on what I should or shouldn’t do!
Thanks in advance!
Posted 06 July 2005 - 12:20 PM
Posted 06 July 2005 - 09:26 PM
After it sat for 16 hours, I could see a small pool of oil and I was just able to “feel” some oil directly under the carb on the mounting plate on the starboard side so I am still leaning towards a leaky hose, but I am afraid I will have to remove the carb, I plan on ordering some gaskets, but I don't know the number...
Any other tips or information that I should be aware of when it comes to the hoses/gaskets for the carb/oil injection if removed?!?!?
BTW: Is there any easier way to work on a Doo than standing on your head with your feet in the air?!?!?!
Thanks in advance for any more tips/information!
Posted 07 July 2005 - 07:57 AM
Posted 07 July 2005 - 08:46 PM
I suppose that not using the oil injection system is an option, but I am not sure if that is the best route to go, maybe if I read some success stories, I might be more inclined to consider it...Thanks for the tip though!What about just removing all of the oil injection stuff and mixing the oil and gas in the main tank? I know it's not the best way I suppose but wouldn't it be a lot easier and still work okay? There are sure a lot of outboard motors running around with pre-mix oil/gas in their tanks and many have been doing so for years and years.
Posted 08 July 2005 - 08:12 AM
Posted 08 July 2005 - 12:35 PM
Posted 11 July 2005 - 06:06 PM
Posted 12 July 2005 - 12:32 PM
#14
Posted 12 July 2005 - 04:12 PM
My friend whom is a person that does have a clue when it comes to mechanics helped me out again tremendously by removing the carb, but found nowhere that it was obviously leaking!
What he did find was that the spring on the lever that allows the oil to flow was off!
Could the spring being popped off cause so much oil to overfill over a period of about 10 months?!?!
Now to read up a bit more and make some new posts about the other probs w/the boat!
BTW: I was contemplating removing the engine entirely as well, but I figured that it would have meant more of a hassle, but I will take the scribe tip into consideration if it ever comes to that...
Thanks again!
#15
Posted 14 July 2005 - 12:03 PM
Hmm, exact same thing happened to me too. Lucky I had the other engine there to figure out how it was supposed to work otherwise I might never have figured it out.What he did find was that the spring on the lever that allows the oil to flow was off!
BTW, i also found another small spring sitting way down deep in the bilge. - couldn't figure out where it came from - maybe foreign? it's a tension spring about 5/8" long and looks like this: O))))))O but the ends aren't closed loops. If you know where it goes - i'd really appreciate it.
