Ski locker not draining / 2012 210 SP
Posted 09 June 2013 - 02:02 AM
- MaroldeBeink likes this
Posted 26 June 2013 - 08:24 AM
Cheers Scott
Posted 01 July 2013 - 01:16 AM
Don't know the answer to your problem Justin I haven't purchased my sp yet, but can you tell me where the table is stored. Are you in Al I lived in Fairhope for 3 years before I moved back to Australia.
Cheers Scott
I just keep mine in the Ski Locker inside its cover.
Posted 18 July 2013 - 09:37 PM
our boat is actually taking on water as well though so i think we have a leaky exhaust or a leak on obe of the drive shafts.
Generally the stringers are molded foam with strategically located recesses in the bottom so that when they are placed in the hull and the fiberglass is laid over the foam, all which is necessary to drill holes through the fiberglass to complete the drains is accessible. The following pictures show typical foam with the drain recesses and holes drilled in the glass.
The first Islandia's off the line for the above year model did not have the recesses in the foam. The holes were drilled in the glass but the foam is continuous. BRP caught most of them but a few units might remain still. Although this is a very specific topic, the concept remains the same for all Sea-Doo Boats – the foam and glass must be drilled for proper drainage to occur. If there is a circumstance of water pooling in the ski locker or center of the hull, the foam might be obstructing the drains, or the holes may simply be plugged with debris over time.
- Justin Fant likes this
Posted 19 July 2013 - 10:37 AM
Intresting now you have me curious. I will have to look at my boat. I never have water.
2010 Sea-Doo Wake 210 310hp & 1997 Sea-Doo GTX
Posted 27 January 2014 - 06:43 PM Best Answer
Solved the issue. I used a snake camera to locate the problem. Turns out it was excess foam blocking the drain.
- Kevin Leclair likes this
