Electrical Problems
Posted 16 June 2005 - 09:56 AM
thanks..
jim
Posted 16 June 2005 - 11:11 AM
Check out our download section , and look at the 2001 manual. It should have a wiring diagram similar if not identical to your 2000.
Posted 17 June 2005 - 05:22 AM
You have a different engine. The 240 EFI is 240 HP. The Opti comes with either 250 or 210 HP.I'm having some problems with the nav lights on a '00 1800 that i just bought.. the owners manual is no help. does anyone have wiring schematics or service manual they are willing to share.. also am a little confused ...see alot about a 240 efi ..i'm assuming that's a 240 hp i was told mine is a 210..can someone clarify.
thanks..
jim
As for the electrical problem, do all the other electricals (horn, blower, bilge pump etc.) function normally?
Posted 17 June 2005 - 10:07 AM
thanks!Welcome to the board!
love this forum
hope to be of more help once i've been around for a while!
jim
Posted 17 June 2005 - 11:27 AM
Thanks or the clarification... nobody ever talks about the 210 ...any info on it??? any issues i should be aware of???You have a different engine. The 240 EFI is 240 HP. The Opti comes with either 250 or 210 HP.I'm having some problems with the nav lights on a '00 1800 that i just bought.. the owners manual is no help. does anyone have wiring schematics or service manual they are willing to share.. also am a little confused ...see alot about a 240 efi ..i'm assuming that's a 240 hp i was told mine is a 210..can someone clarify.
thanks..
jim
also ..yes all the other swiches work fine including the anchor and dash lites on the fist stop of the lite sw....although the low fuel alarm sw has no internal light ..not sur if that's connected or just a problem with that particular switch.
just downloaded the manuals for the 2001 and the 99 at tiggerman's suggestion... i think the only real difference beween the 00 and 01 is they elimminated the low fuel alarm sw.
these should help.
i'll let u know!
