Engines running at different RPM's
Posted 15 June 2005 - 10:45 PM
Posted 16 June 2005 - 10:13 PM
The engines at different rpm with the levers in the same position isn't uncommon. It is just a matter of how the throttle cables for each engine are adjusted most likely. Sounds like the idle adjustment on 1 engine is adjusted a bit different.Hello folks, I have just purchased a 1996 Sea Doo Speedster and when I took it out for the first time I noticed that my RPM's do not match up (around 1000 less on left engine) with both of the throttle levers in sync. Does anyone know what could be causing this and how to fix it? At idle the left engine is also lower rpm around 300 or so. Thanks for any help.
Doesn't sound like anything mjor. You can find the idle screw and adjust either engine so they match. My engines both idle at 1500rpm. You can also adjust the cables if the engine rpm thing is anoying.
Posted 17 June 2005 - 04:42 PM
OK thanks was thinking something must be wrong with the left engine. Thanks again for the help. MikeThe engines at different rpm with the levers in the same position isn't uncommon. It is just a matter of how the throttle cables for each engine are adjusted most likely. Sounds like the idle adjustment on 1 engine is adjusted a bit different.Hello folks, I have just purchased a 1996 Sea Doo Speedster and when I took it out for the first time I noticed that my RPM's do not match up (around 1000 less on left engine) with both of the throttle levers in sync. Does anyone know what could be causing this and how to fix it? At idle the left engine is also lower rpm around 300 or so. Thanks for any help.
Posted 19 June 2005 - 02:53 PM
