2012 wake 210 will not start
Posted 14 May 2013 - 09:59 PM
Thanks, DJ
Posted 15 May 2013 - 07:06 AM
Did the boat go through a proper PDI before you took delivery of it? It sounds like the dealer may have missed something in this inspection, so I would recommend reaching out to your dealer to determine a time when you can bring it in for some diagnotics since it appears you have checked the logical possibilities already. Keep us posted.
Posted 15 May 2013 - 02:23 PM
Posted 04 June 2013 - 09:28 AM
Did you have power on the guages? If not Check wiggleing the cables on the battery posts. If they are loose this can create the same issue you describe.
2010 Sea-Doo Wake 210 310hp & 1997 Sea-Doo GTX
Posted 04 June 2013 - 01:34 PM
I had the same thing happen to my 2012 wake 210 last summer. I thought that I was going to be calling for a tow. I stuck my head into the compartment in front of the steering wheel and felt the various wires and found that a wiring harness connector had come slightly apart. When I pushed them together everything was fine.
I also had another incident where the power and key were on but the screen was blank and the motors turned over but didn't start. This is different than you scenario but what fixed this was turning the battery switch and key off and then back on. Some kind of computer reboot!
Posted 12 June 2013 - 10:16 PM
I know how you feel Kman, about having your head in that compartment in front of the wheel. I've spent more time up there trying to fix this boat than I have been out on the water!
Posted 15 June 2013 - 12:38 AM
Posted 17 June 2013 - 10:38 PM
Posted 22 July 2013 - 09:39 AM
Hey I had this same problem to my new 210 wake this last week. I tried everything like you what i did was shake the rear jet gates up and down and it started. I phoned my dealer and they mentioned a neutral switch....where is it can i do the work myself so i dont loose boat time?
Posted 22 July 2013 - 10:50 AM
Should be able to find the neutral switch here in one of the breakdowns:
http://epc.brp.com/I...59-9e6f9ab5a5dc
Posted 01 August 2013 - 06:32 AM
thanks, i have tried something else. if the boat wonder start in neutral i put shifter all the way full back to neutral and back to reverse all the way then back to neutral and it works....i think maybe adjustment on the throttle cable?
