can anyone identify the diferent parts within the impeller housing for me
i am aware of the stators - wear ring impeller and pump
i just dont know which is which
i will attach a photo
impeller parts
Started by thumper, Jun 09 2005 03:14 AM
7 replies to this topic
Posted 09 June 2005 - 03:14 AM
Posted 09 June 2005 - 03:29 AM
here ya go - heres my go
a - stators
b - impeller
c - wear ring
d - pump (looks like aircraft engine turbine)
am i close?
a - stators
b - impeller
c - wear ring
am i close?
Posted 09 June 2005 - 09:03 AM
Close. In your photo:
A-points to an impeller blade. Looks like a 4 blade.
B- points to the wear ring (grey)
C- points to a stator vane. So does D.
The pump would be classified as the entire assembly, from impeller aft.
Posted 09 June 2005 - 11:31 AM
thank you for clearing that up
so what does the stator vane doo - is it fixed to the drive shaft as the impeller or something else????,,....
Posted 09 June 2005 - 12:35 PM
The vanes take the swirling motion and settle it out for more efficient thrust. The end of the pump is the nozzle which controls the venturi effect and helps accellerate the water for more thrust, this is not to be confused with the steering nozzle which is the last piece sticking out from the pump area.
Wakeboard Tower, Bimini Top, Aquatic AV Stereo w/ Wired Remotes, Sony Xplod amp, 2 - 10" Subs, 6.5" Polk Audio Spkrs, Bazooka Tower Spkrs, Custom Cold Air Intake, Custom Rotax Racing Thru-Hull Exhaust, XS Power External Intercooler, Filled Rideplate Holes
Posted 10 June 2005 - 03:04 AM
does the stator vane spin freely or is it driven?
Posted 10 June 2005 - 05:12 AM
The only rotating part is the impeller. The stater vanes are "fixed" and just take the "spin" out of the water stream as it leaves the impeller. You can see the angle on them in your picture.does the stator vane spin freely or is it driven?
Steve
Posted 10 June 2005 - 09:15 AM
thanx for clearing that up for me
