Testing my new Go Pro Hero 3 Silver on my water ski using the surf board adaptor. I used the adaptor that allows the Go pro to be tilted back further but with this one you can't use the rubber safety piece that stops the Go Pro from coming loose. The small second safety cord connected to the second small stick on mount held fine evan at 32 MPH. I found out that the second mount that comes with the kit does allow the robber safety piece to be used but for the water ski does not allow the Go Pro to be tilted back far enough (Video To Follow). Boat was a 1998 Sea Doo Speedster which still pulls this 92kg guy out with both feet in with no problems. In fact my 2012 Sea Doo 180 SE only pulls a little harder but the new boat cavitates badly with hard exceleration so is harder to drive. | From:Brad Shawcross Views:1 ![]() ![]() ![]() ![]() ![]() 0ratings | |
Time:01:19 | More inComedy |
View the full article
