How to remove the carburetors on a 1998 Seadoo speedster. The boat has twin 787 rotax engines. Sorry about the crappy lighting 1. Slide the tabs back on the air box 2. Remove the airbox cover, be careful of the seal if you need to use a screw driver 3. Remove the 6 bolts (#10 socket or #5 hex depending on carb) holding the plate holding the airbox and remove the box 4. Remove the air filter, be carful not to damage the seal 5. Remove the 4 hex head bolts (#5 hex) in the intake box and the 2 bolts holding it to the exhaust manifold 6. Using an allen wrench loosen the set screws holding the choke cable shaft 7. Loosen the jam nut holding the cable end and remove the cable from its holder 8. Remove the 4 bolts (#6 hex) holding the carb to the engine. I left one on so it was easier to get the fuel lines off 9. Remove the 2 fuel lines from the carb 10. Remove the oil pump cable 11. Remove the throttle cable | From:mtrain999 Views:3 ![]() 0ratings | |
| Time:12:42 | More inHowto & Style |
View the full article
