Disassembling the 2 stroke rotax 787cc engine from my seadoo speedster. The engine threw a rod after a piston rod bearing went bad. I had the engine apart already which is why some of the gaskets are missing. As you can see it blew a hole in the lower crankcase and the piston was making contact with the head. Since the crank is bad I really didnt care which is why I removed the pistons with a hammer. | From:mtrain999 Views:3 ![]() 0ratings | |
| Time:22:10 | More inTravel & Events |
View the full article
