Sea-Doo BOMBARDIER GT 3-SEATER FAMILY JET SKI 5810. Engine is by ROTAX 650cc / 55hp, (Yellow Block) and is a TWO STROKE AUTO-LUBE / PETROL. Is a 1992 Model with Reverse Gear. Suitable for Towing Inflatable Toys and Water Skiers... HANDY TIPS: • REMEMBER THAT JET SKIS ARE EXTREMELY POWERFUL MACHINES AND WE ALL LOVE ADRENALINE RUSHES. HOWEVER WE NEED TO BE AWARE OF RULES AND DANGERS. MAKE SURE THAT OTHER BOAT/JET SKI USES AND THAT OF OTHER USERS OF THE LAKES AND THE BEACH ARE SAFE TOO! ENJOY YOURSELF BUT USE YOUR HEAD. BE AWARE OF SWIMMERS AND OBJECTS! ALWAYS ATTACH YOUR SAFTEY CUT-OUT PULL CORD. MAKE SURE YOU HAVE A DSC/VHF MARINE RADIO, ANCHOR, AND OTHER SAFETY EQUIPMENT WITH YOU. TELL SOME-ONE ON LAND WHERE YOU INTEND TO USE YOUR JET SKI AND WHAT TIME YOU ARE DUE TO BE BACK OUT OF THE WATER. • If need to use 2-stroke oil in your Jet Ski. NEVER MIX DIFFERENT BRANDS OF 2-STROKE OIL! Use the same brand. Should the brand you use not be available, as long as the oil you want to buy is recommended, simply drain-out what is left of the old 2-stroke oil. • Having your Jet Ski regularly Serviced and Winterized will keep her in tip-top condition. • If you hear a clicking a sound, it may be the starting motor sticking. Maybe it is the solenoid at fault? The easiest way to test the solenoid is with a test-light. Put the test-light in the terminal. • Is the starter in your Jet Ski stuck? Take out the starter and test it with jump-leads. If it is stuck tap the side of starter using <b>...</b> | From:GowerWaterSports Views:0 ![]() 0ratings | |
| Time:08:31 | More inEntertainment |
View the full article
