Sea-Doo BOMBARDIER GT 5810, THREE MAN FAMILY JET SKI, Engine is by ROTAX 650cc / 55hp, TWO STROKE AUTO-LUBE / PETROL. Handy answers and tips to questions about Jet Ski starting problems: If you hear a clicking a sound, it may be the starting motor sticking. Maybe it is the solenoid at fault? The easiest way to test the solenoid is with a test-light. Put the test-light in the terminal. Is the starter in your Jet Ski stuck? Take out the starter and test it with jump-leads. If it is stuck tap the side of starter using live jump-leads. You should examine all leads and connections that they are in a clean condition and are all tight and securely attached. Examine the spark plugs... More tips. ALWAYS USE FRESH OIL AND FUEL. ALWAYS ATTATCH WEAR YOUR SAFTEY CUT-OUT PULL CORD. LWAYS TELL SOME-ONE WHAT TIME YOU ARE DUE TO BE BACK OUT OF THE WATER AND WHERE YOU INTEND TO BE USING YOUR JET SKI... Here is the link to the manual: seadoomanuals.net PLEASE BE WARNED. I AM NOT A MACHANIC. IF YOU ARE NOT CONFIDENT AND TRAINED TO SERVICE YOUR JET SKI YOU SHOULD TAKE IT TO AN AUTHORIZED DEALER... | From:GowerWaterSports Views:25 ![]() 5ratings | |
| Time:05:35 | More inPeople & Blogs |
View the full article
