Hello,
I have 1998 1800 challenger. I got new carbs for it. However i can't seem to find the fuel line that attaches the carbs to each other from the accelerator pump to both carbs. It is the smaller fuel lines. I when to the auto stores and they had nothing. They did have the 1/4" size. But not the smaller size. Anyone know where i can get this? I tried the seadoo part stores. However they say its disconitinued. I have everything else to put them together to get the boat going but just need this fuel line..
Fuel line help
Started by Brandon Paul, Jun 20 2012 08:50 AM
Posted 20 June 2012 - 08:50 AM
Posted 14 November 2014 - 11:06 PM
Have you tried using the slightly larger line with a cable clamp? I believe that should work.
You can also get rid of the accelerator pump all together and go with a slightly larger idle jet. I've considered removing my accelerator pumps and going with larger jets, since I can't get the pumps to reliably squirt the same volume of fuel into both the MAG and PTO carbs when priming the system with the throttle shifters.
