Handy answers to questions: If you hear a clicking a sound, it may be the starting motor sticking or maybe it is the solenoid is at fault? The easiest way to test the solenoid is with a test-light. Put the test-light in the terminal. Is the starter in your Jet Ski stuck? Take out the starter and put jump leads on it. If it is stuck, tap the side of starter using live jump leads. You should examine all leads and connections that they are in a clean condition and are all tightly attached. Examine spark plugs... Here is the link to the manual: seadoomanuals.net WARNING. I AM NOT A MACHANIC. IF YOU ARE NOT CONFIDENT AND TRAINED TO SERVICE YOUR JET SKI YOU SHOULD TAKE IT TO AN AUTHORIZED DEALER... | From:GowerWaterSports Views:7 ![]() 1ratings | |
| Time:01:35 | More inEntertainment |
View the full article
