I created a how-to guide for installing a 2nd battery, please let me know what you think. When I migrated from Word to PDF, it added some space. But let me know if I let some gaps!
How to guide for 2nd Battery for 2010 180 SE
Posted 02 April 2012 - 10:28 PM
- Herman1KY, Hisham Saad and KammaimbNiz like this
Posted 05 April 2012 - 02:16 PM
Posted 11 April 2012 - 11:02 PM
Posted 13 April 2012 - 08:46 AM
Posted 13 April 2012 - 08:47 AM
Posted 19 April 2012 - 06:40 PM
I know this will be a dumb question, but when is it best to use each setting on the battery switch? Should Battery 2 just be used say when I am anchored in the cove listening to the stereo? When is it best to have both batteries on? Just curious as I would like to install this on my new 2011 180 at some point because I also want to upgrade some of the audio components without killing the battery when listening on the water. Thanks!!
Hello!
You can run your boat in the "Both" setting, and when you want you sit out in the boat for hours on end and you are concerned about running the battery down just move the switch to "1" or "2".
WARNING! Just DO NOT switch the batteries while the engine is running as this could/will damage your alternator.
I personally run in "Both" and then when I plan to run the radio's and stuff for a long time, I will switch to either "1" or "2".
Then when I am ready to leave, you can try to crank or move to "Both".
Questions?
