Hi , I have a speedster 200 ( 430hp ) and struggle to pull out one large skier quick enough with three people.How can I increase torque with out lowering my top speed ?
Can changing the pitch of the props improve the accelaration ?
Acceleration
Started by sebster 200, Feb 04 2012 05:55 AM
Posted 04 February 2012 - 05:55 AM
Posted 10 February 2012 - 12:16 AM
new wear rings
Posted 11 March 2012 - 11:01 PM
Hi Kevin , just got the boat back and very happy with it . I had Solace props put in , rebuilt the superchargers with a bigger wheel ,washers etc and increased boost to 10.5 PSI and yes new rings.
it's still struggles of the mark but mid and top range is so much better.
I wanted to ask you if you had any problems with the forward neutral reverse shifter . When pushed all the way onto forward it comes back up a little and stays . It causes problems at times because you cant engaged the throttle levers forward. You need to keep holding the lever all the way down with your other hand to engaged the throttle levers. Do you think the cable is stretch , should I replace the lot ? Im having problems obtaining a manual to help me through it . I hope it makes sense .
Thanks Kev .
Thanks Kev .
