Hi, new to the forum. Just got my 2011 180 Challenger SE 215HP a few months ago. Was curious about my speedo reading as it seemed slower that it felt. This evening used GPS and assuming my GPS is accurate here is what my speedo said.....36MPH @7780rpm....GPS said......45.7MPH @7780rpm. On average throughout range speedo was off about 7-9MPH. I only have 5 hours on the boat so I could not push her at WOT for too long since I am still breaking the engine in. After break in, if the boat will push up to 8000rpm then I may get more speed. I am at full rpm now with almost a 1/4 throttle left to give but no extra rpm when I push to full, will this change after break in period? Does anyone else notice this? I guess I will find out at the magical 7-10 hours when the computer says it is ok to go wide open, LOL!
2011 Challenger 180 SE Top Speed
Started by physio, Sep 19 2011 05:42 PM
8 replies to this topic
Posted 19 September 2011 - 05:42 PM
Posted 24 September 2011 - 06:32 PM
Your throttle after break in will advance but more throttle throw is needed for a small rpm increase. My 255hp goes to 7700, but hole shot can get it to 8000 before it bites. After 10 hrs the performance diff is really insignificant, but it won't burn quite as much gas, and the change of oil will stop the oil loss as the new stuff doesn't need to glue the engine. You'll love the boat. Generally you can run faster In this than the twins without burning ridiculous amounts of fuel. Ie much better economy at the top end.
Cheers
Cheers
Posted 29 September 2011 - 08:07 PM
I have a 2008 Challenger 180 with the same 215 Hp engine and found the GPS and spedometer both match within a couple miles per hour. With 3/4 tank and three people the boat we can do about 45 to 48 mph depending on water conditions full throttle. You may wish to have the spedo checked out at the 10 hour inspection to see if the spedo is Ok. We noticed a change for the better with fuel consumption after our 10 hour break in period. Really has been a great family boat.
Posted 30 September 2011 - 07:37 PM
Ok, thanks, I'll have the speedo checked, can the gate be adjusted to give a close to true neutral, the forward propulsion in neutral is fine but I have to keep toggling between neutral and reverse to hold the boat steady when trying to stop the boat for docking or just want the boat to stay still?
Posted 09 May 2012 - 10:51 AM
Do you have mods? I have never got over 37 MPH with my 215. I also talked with Seadoo internal and they say that is as fast as it goes. Please confirm.
dootndo2
dootndo2
Posted 20 May 2012 - 04:59 PM
What am I looking for at my 10 hours? Does a light come on or something?
Posted 16 August 2012 - 06:29 PM
I also have a 2011 180 with the 215 hp engine. my speedo has never read over 23mph and others that i have talked to with the same year boat has been having problems with their speedos. with my GPS i reach high 40s and i know GPS is accurate.
Posted 17 August 2012 - 06:14 AM
I got same boat 2011 c180 se with 215HP and my Speedo has never shown more than 32. But when I check with my GPS, it's close to 43.
Posted 21 August 2012 - 05:29 PM
Altitude can also have a lot to do with top speed and over all power. I was just running at 4700 feet above sea level and had a significant decrease in top speed. I also had about 1000 less RPM than I normally do where I usually ride at around 250 feet. My Speedo has never been accurate though. Usually reads 10-12 below what GPS says on the top end. Where I ride water current also affects readings.
On Land:
2005 Chevy Silverado 2500HD LLY Duramax
1975 Chevy K5 Blazer SB400
2008 Polaris Outlaw 525 built for sand
2011 Yamaha FZ8
On Water:
2011 Sea-Doo 180 Challenger SE
2011 Yamaha FZ8
On Water:
