Recently my 2003 speedster has developed a streaming hot water leak from the lower portion of the motor on the passenger side. It is not leaking were the motor meets the fiberglass, but seems to be between where two pieces of metal meet which is about an inch above the fiberglass. There is a small brass fitting near the leak with a gray hose on it, Thought it might be the leak. I removed the hose cut off an inch and clamp it back on. The leak continued. Upon closer inspection I found the leak. With the boat out of the water and on the water hose the leak is not as strong, however running the boat there is a nice stream. Again it is hot water. This has been a great boat, as u can see I have had it for a while and plan on replacing seats and decals. Any help would be greatly appreciated. Hoping to avoid pulling engine!
Hot water leaking from lower motor on speedster 240 p
Started by Geno, Aug 31 2011 05:03 PM
No replies to this topic
