Thanks much
97 speedster Taking on water?
Started by Nstsized, Aug 27 2011 09:27 AM
Posted 27 August 2011 - 09:27 AM
I recently boat a used doo boat and it takes on water while sitting a dock...any easy suggestions on where it might be coming in from...Checked the obvious already...I'm no mechanic so be esy on me
Thanks much
Thanks much
Posted 27 August 2011 - 01:24 PM
Check the boot around the exhaust port exiting under the rear deck. I had to replace mine on a 98 this season. The leak was about a one cup per min. My cooling inlet off the pump fitting also drips slowly.
Posted 27 August 2011 - 08:56 PM
ThanksCheck the boot around the exhaust port exiting under the rear deck. I had to replace mine on a 98 this season. The leak was about a one cup per min. My cooling inlet off the pump fitting also drips slowly.
Posted 29 August 2011 - 02:01 PM
On mine I get a little leak around the fittings for the cable going to the weedless system on the intake.
