I'm replacing the carbon seal on my 96 seadoo speedster and in the shop manual it says you need a special pair of pliers. Is there an alternative way to getting it off instead of buying these special pliers. Thanks.
Carbon seal replacement question
Started by Jessica Savage, Aug 20 2011 01:37 PM
Posted 20 August 2011 - 01:37 PM
Posted 20 August 2011 - 05:34 PM
Ok never mind on the previous question, I got the clamps off, but the next step in the shop manual it says I need to push the stainless steel piece toward the back of the boat and remove the o rings. On my boat this piece is stuck and will not budge. Are there any tips or tricks to loosen it?
Posted 22 August 2011 - 11:19 AM
I tapped mine back with a small hammer. And since everything was apart I retrofit it with a seal carrier. I picked up the carrier here onlyseadoo.com
Instructions
http://seadoosportbo...rrier-retrofit/
Instructions
Posted 23 August 2011 - 12:14 PM
It will tap backwards toward the outdrive and uncover the o-ring seals and whatever corrosion or mung exists.
If you are replacing the SS flange anyway (I did), you can tap it harder (didn't have to).
