My speedometer and fuel gauge and tachs don't work. Well sometimes the tachs do but they sit at 5500 rpm when full bore. I cant find any loose wires etc. Any ideas would be appreciated. Thanks
-Scott
				1998 challenger 1800 electrical issues and questions
		 Started by Kooncie, Aug 02 2011 02:38 PM
		10 replies to this topic
			Posted 02 August 2011 - 02:38 PM
			Posted 02 August 2011 - 03:16 PM
					Have you checked the fuses?
	Need a shop or part manual for your boat or PWC?  Join the SDSB Club here, http://seadoosportboats.com/join and download them here, http://seadoosportboats.com/manuals
			Posted 02 August 2011 - 11:30 PM
					I had sticky tachs on my 95 Speedster.  Took the bezels off (carefully with a needle nose pliers) and found the needles were rubbing on the bezels. Put one drop of light oil on the tach shaft. Put them back together (very carefully) with Black rtv.  Problem solved.
			Posted 03 August 2011 - 10:37 AM
					Where are the fuses? If its not that I will try Overkills idea.
I bought this from my folks where it has spent the better part of 8 years going to the lift in the spring and back to the trailer in the fall. We cant find the manual so I need to get one. They bought it new in 98 so we could tube and ski etc. I had to do a lot of work on it to get it running again like carb kits, wear rings, impellers, oil and gas lines and filters. Sitting was not good with a bad cover either. One we began using it this year the seats cracked etc.. We have a larger boat so we drag this with us and tube and ski the kids and rip around in it. We even used our 93 sp this weekend that is all original less a carb kit. Any hints are helpful. A friend recommended I join this site because of the wealth of knowledge here. Glad I did. Thanks!!!!
			Posted 03 August 2011 - 10:51 AM
					There should be a fuse box/panel close or underneath the helm (that is where they are on most of these boats).  Keep us posted.
You can get a free operators guide for the boat here, http://en-us.sea-doo...ors-guides.aspx
If you want more detail I recommend the shop manual which can be purchased here, http://seadoosportbo...00-shop-manual/
			Posted 03 August 2011 - 02:09 PM
					Thanks Kevin, I will look when I get home. I downloaded the manual and printed that off already. I will update tomorrow. Thanks
_Scott
				_Scott
			Posted 04 August 2011 - 11:14 AM
					OK, so after working on it last night the fuses were good although I discovered a mess in the electrical boxes for both the port side motor and starboard motor. Both were heavily corroded and the port side was missing the gasket so it was full of water. Tonight I will clean up the connections and install a new gasket and see what that does. That could be my issue I hope. However I noticed a bad through hull fitting on the port side reverse/forward cable that is broken. I will try some special caulking that cures under water and bonds to anything from 3M.
After all this I looked at the side of the boat an realized my boat is a 1800 sportster
 electric box.jpg   107.18KB
  19 downloads
 forward-reverse thru hull fitting.jpg   102.39KB
  18 downloads
  19 downloads
  18 downloads
			Posted 04 August 2011 - 11:02 PM
					Gunky looking hull.  If you want to clean it so it looks new Spray9 works fantastic.  I agree that you have to get the electrical box clened up before trying anything with the tachs.  Good luck and keep us posted.
			Posted 09 August 2011 - 10:07 AM
					So I got this all cleaned up changed out all the fuses and still nothing. Runs like a top though. This did cure the battery going dead all the time. That's about it though. I put new gaskets on the electrical boxes.
Changed out all the oil lines and fuel lines. I just checked one oil line and it cracked right in my hand. So I decided to change all of that stuff out.
So there are a few holes in the gauges in the back. Which one should I put a drop of oil in. Any other ideas what I might try or test? Everything electrical works on the boat except the gauges
Thanks for the help!
Scott
Scott
			Posted 23 August 2011 - 01:15 PM
					Anyone? Buehler?
			Posted 26 August 2011 - 11:17 PM
					There are electrical troubleshooting charts in the manual that might help you track down if it's the guages or something else.  The guages should be fully sealed so there shouldn't be anyplace to add oil on the back.
ANy chance you can get other guages to test with?
At least it runs good.
