Another C180 with cavitation problems
Posted 28 July 2011 - 11:59 PM
Took the boat back this season, they claimed that the wear ring is worn beyond spec. The spec is 14 thou and mine is worn to 15 thou. I have 20 hours on the boat and they wont warranty the ring because its a wearable item. So I pay to replace it. They checked the carbon seal, the pump seal and the ride plate again. Called me today and said they tested it and that it was fixed.
I took it down to the river after work, it is better but I still cannot launch using full throttle. The best I can do is 50% and then it cavitates after that.
Extremely dissapointed with this boat. Taking it back to the dealer tomorrow.
Is there honestly any one that owns one of these boats that can be sitting at a dead stop in the water, slam the throttle all the way forward and have the boat launch without cavitating?
i would be interested to hear any kind of success story with one of these boats. Everyone I have talked to in person has this problem and most of the jet boat forums are littered with horror stories about this boat.
Posted 29 July 2011 - 11:13 AM
Keep us posted.
Posted 29 July 2011 - 12:27 PM
So you could be at a dead stop and snap the throttle wide open and it wouldnt cavitate?
Posted 29 July 2011 - 08:12 PM
Posted 30 July 2011 - 08:48 AM
I also have C180. Never had any of these problems in the three years I've had mine. It's a great boat and has no problem pulling skiers. Keep pressing the dealer to get it straight for you. Good luck.Yes we could.
Posted 30 July 2011 - 10:01 AM
Posted 01 August 2011 - 07:49 PM
Posted 01 August 2011 - 08:28 PM
Posted 02 August 2011 - 10:23 PM
I have an 08 and don't think I have any problems. What exactly does it do when it cavitates?
If you quickly push the throttle all the way to the wide open position from idle the engine hits the rev limiter and the boat doesnt accelerate. I can only open it up about 1/2 throttle or else it cavitates and then I have to back off the throttle and start again.
Thanks to the few of you that stepped up and responded that your boat works the way its supposed to.
Posted 02 August 2011 - 10:30 PM
Ill let you know if they come up with a fix.
I found this on you tube. not my video but it gives you an idea of what cavitation is. Mine cavitates a lot worse than this boat does.
Have a look:
Youtube cavitation video
Posted 31 August 2011 - 07:29 AM
Posted 31 August 2011 - 01:54 PM
Posted 18 March 2012 - 04:03 AM
#14
Posted 10 May 2012 - 01:07 AM
After reading about your experience I'm a little frightened honestly - especially seeing as the closest dealer is 2.5hrs away. I checked the intake (clean) and the impeller looks good so I'm not sure what to think. I have the boat booked in in 2 weeks but I'm not very hopeful.
CAN ANYONE TELL ME HOW TO CHECK IF THE RIDE PLATE LEAKS??
Also, if anyone can point me to something else that could cause this I would really, really appreciate it. It was pretty disheartening for the family when the thing ran like crap.
cheers!
#15
Posted 11 May 2012 - 01:17 AM
My boat is supercharged so i cant see why the dealer should have to install a different impeller than what is supplied with the boat (assuming there is one supplied). Also, he figured that it had been accidently exchanged with a non-turbocharged unit. It seems like it cavitates however when you crank the steering wheel to either side you can pretty much get the jet to "hook up" then it seems pretty fun actually.
please anyone - any thoughts?
#16
Posted 11 May 2012 - 01:18 AM
#17
Posted 16 May 2012 - 01:38 AM
Now I called 3 separate dealers from two different states right after I knew my boat had full throttle from standstill cavitation, and at the time thinking it was an issue I should be concerned with. ALL 3 had the exact same answer: it is normal. In fact, two of them were kind enought to detail the reasoning: simply put, they said it is like too much power in a car -- full throttle at standstill and you just sit and spin and probably hit the rev limiter until the car gets going or unless you let off. Hmmm, sound familiar? Now I know some may think "wait a minute, how can the pump suck up ALL the lake water? Well of course, it isnt doing that. It is actually "overpowering" the water going in. With high output, at some point the impeller requires more fluid (water) then the fluid can actually flow in. This creates a void in which, you guessed it, air fills, and walah! cavitation. Some will not understand this, and think that water should flow as fast as the impeller throws it. This may be true on the output side of the impeller, but nothing is actually "pushing" the water on the intake side and so it relies on being "forced" in by the boat moving faster until this "forced" intake matches what the pump is demanding.
Simply put, when you floor it on a high powered boat, you demand more water then what is available for a little while until your boat speed starts to "shove" water into the intake. As far as the problem seemingly going away and allowing full throttle when the wheel is turned, I was explained that this is actually caused by some of the back pressure of the pump having to now push water down an angle instead of a straight through, and the back pressure allows the pump to stay full. This is evidenced by the thrust at full lock of the steering wheel at full throttle not quite being as much as going straight.
There is so much on the internet today about these boats having "problems" because you cant full throttle from a standstill. I am one who does NOT think there is a problem. I think engine output numbers have grown to a point that you simply cannot full throttle whenever you want anymore, just like a car with a powerful motor. And I actually think having TOO much power is a "problem" I am proud of! As long as you know how to control it, these boats are some of the highest performing boats the general public can buy!
- radiofred likes this
#18
Posted 17 May 2012 - 08:38 AM
I owned a powersports dealership for a decade (not marine though), went to college in a mechanical related field (automotive mostly), and overall have been in some sort of automotive,powersports or heavy equipment field for around 20yrs. I totally understand what you are saying as there are obvious limitations when trying to get a boat this size to be able to get all 255 horses to the water as efficiently as possible without any cavitation - especially if the same basic pump is being used regardless of boat size, type, usage or horsepower - of course there are minor differences internally but it is not engineered specifically for this boat. They can't just add another 40 horspower and a more agressive impeller and have a set-up that won't cavitate whatsoever. I understand all of that.
This issue isn't at all like having too much power in your hot rod and spinning your tires on pavement, it's actually just like having your hot rod on black ice (I'm from Canada, I know what this is like). There is seriously something wrong with this boat - they would have never-ever brought it to market like this purposefully. It isn't a matter of feathering the throttle until it gets up to speed - max speed is around 15mph! The dealer pulled the pump apart and found nothing wrong, replaced the wear ring, some seal (I was driving when I took the call and didn't catch which seal) and they re-sealed the ride plate. I'm picking it up tonight and can't use it until the sealant used on the ride plate fully cures which is supposed to be on Saturday. Guess we'll see...
#19
Posted 17 May 2012 - 07:34 PM
Good Luck.
#20
Posted 18 May 2012 - 09:11 AM
Any updates on yours redrooster?
