My 2010 Challenger 180SE has done 15h and today I noticed irregular RPM when at 5600RPM. there was a variation of 300 rpm jump up and down. when at full throttle or below 5000 rpm the irregularity does not happen. however I noticed that full RPM was slower to reach than usual
I appreciate your suggestions. Joe
irregular RPM between 5000&6000 rpm
Started by jorous, May 28 2011 11:28 AM
Posted 28 May 2011 - 11:28 AM
Posted 02 June 2011 - 07:32 AM
Sounds like cavitation. Are you aware if you sucked up anything in there? It is possible that your wear ring is damaged and is causing these symptoms.
Keep us posted.
Keep us posted.
Posted 03 June 2011 - 11:27 AM
I today noticed some water leak (spraying) from the behind the exhaust while flushing the engine. the water is leaking from behind the yellow rubber gusket. I tried tightening the knot but could not find the right tool. I guess I should take it in for a proper check. Thanks for your reply
