1998 2x 110hp engine. I have a dual temperature sensor. Behind the sensor, the wires are cut.
I want to connect the sensors to the engines. Is this a difficult process? If not, should I purchase a manual for the engine?
Thank you
Rick
Florida!
Temperature sensor location on engine
Started by rickfl, May 19 2011 03:20 AM
Posted 19 May 2011 - 03:20 AM
Posted 19 May 2011 - 04:35 AM
I subscribed to the site, download all of the pdf manuals associated with my engine/boat. I cannot find anything about replacing or understanding how/where the temperature sensors on the engines connect to my dual temp gauge, which has many disconnected/cut wires behind it. I searched for "temperature" in each manual.
There are so many wires under the drivers side hatch but I do not see how my temp gauge connects to anything. Any help is appreciated.
Rick
Rick
Posted 21 May 2011 - 09:44 PM
Hi Rick tried searching the net and couldn,t find anything. Maybe your local dealer could help you out with some photocopies?
Good luck.
Good luck.
YOU CAN'T BE FIRST...BUT YOU MIGHT BE NEXT
