I can start if right back up without even touching the switch/lanyard. It seems to happen near full throttle and not all the time...........
Posted 03 August 2004 - 06:23 PM
Posted 03 August 2004 - 07:22 PM
Posted 03 August 2004 - 08:17 PM
Posted 04 August 2004 - 07:59 AM
Check the fuel filters/water separator first, then look at your plugs. Check all your spark plug wires for good connections at the plugs.My engine cuts out every once in awhile....almost as if the kill switch is pulled off. Anyone else experience this?
Posted 04 August 2004 - 12:29 PM
I changed all the plugs........although the old ones looked fine. Removed and re-connected all the wires too......Still happening....!!!! It does not happen all the time so its hard to nail down. I will try a few different things to see if I can cause it to happen.Check the fuel filters/water separator first, then look at your plugs. Check all your spark plug wires for good connections at the plugs.My engine cuts out every once in awhile....almost as if the kill switch is pulled off. Anyone else experience this?
You don't have RAVE valves and you dont have high speed screws on your 240EFI ..
