Think I got a junk set of rings? I dont know the specs of the solas impeller diameter.
Wear ring 98 speedster
Started by bryckhaus, Feb 15 2011 12:32 PM
Posted 15 February 2011 - 12:32 PM
So I had my pumps out for the winter and just got around to them cause one had a gash I wanted to replace. I had purchased 2 rings a few months ago I forgot were I ordered from. However the old ring was tight to the impeller not much gap like .021 ... the new ring has a huge gap .037 at the top and .030 on the rest.
Posted 15 February 2011 - 12:43 PM
Also it has solas sd-sc-k 16-21... solas website recommends 15-23 whats the difference?
Posted 22 February 2011 - 03:49 PM
It might be best to go directly to Solas on this one, keep us posted what you find out.
Posted 24 February 2011 - 08:51 AM
That gap is huge. The impeller should not make any difference. You still use the same wear ring. I think you got a bad wear ring. Where did you order from? I dont mind buying some aftermarket stuff, but on a wear ring, OEM is the only way to go. There are tons of stories of people getting bad wear rings from places like ebay.
