Engine Overheating
Posted 11 October 2010 - 11:22 AM
Noticed reduced hull speed at idle, then got high temp alram on port engine. Sounded like debris in the impeller. Shut down the engine, and idled back to our dock on one engine.
Ironically, our outing today was to take our Doo to the boat ramp to haul it out and put it away for the season! Now I'm stull stuck in the water.
It's fall here so there a lots of leaves etc. floating in the creek, so I assume we sucked up enough debris to plug the exhaust cooling intake?
If so, how do I flush out the exhaust with the boat still in the water?
Posted 11 October 2010 - 11:56 AM
Posted 11 October 2010 - 05:13 PM
The boat is currently safe at my dock, but the closest ramp is about 10 miles away... long haul putting along on one engine.Can you not make it back to the ramp on one engine?
I was hoping I could solve the problem with the boat still in the water at my dock.
Posted 11 October 2010 - 05:22 PM
I have never actually tried flushing while in the water so you might want to check the manual to see if this is even possible.
Do you have a way to get a hose with running water to your dock?
Posted 11 October 2010 - 07:08 PM
Yes, I can get a hose to my dock. I just don't know how to flush it. The manual just shows flushing from a port on the transom. I was hoping I could do it from inside the engine compartment somehow?I see, yeah that is quite a haul on one engine. I am not sure how much it would help but have you tried flushing it while in the water?
Posted 11 October 2010 - 07:26 PM
Posted 12 October 2010 - 08:59 AM
Posted 12 October 2010 - 06:48 PM
Thanks, Kevin.See if this helps, I pulled this out of the manual for flushsing the the exhaust system.
10-12-2010 9-56-41 AM.png 670.95KB 10 downloads
10-12-2010 9-57-02 AM.png 849.29KB 11 downloads
10-12-2010 9-55-54 AM.png 435.89KB 7 downloads
If I remove the hose that runs from the transom to the top of the exhaust, I may be able to connect a hose at that point (as the boat is still in the water).
I am going to talk to my dealer tomorrow to see if they have any other suggestions.
I'll let you know how I make out.
Curt
Posted 13 October 2010 - 08:29 AM
Sounds good, looking forward to hearing how it turns out. Thanks.
