Has anyone put a charging system in this boat?If so I would like to see pics..My battery is dead about the third time I take it out and I always have to take the time to take it completely out and charge the battery and replace with a second battery off my other boat.If theres a easier way please someone tell me it would be greatly appreciated..Thanks
Mike proud owner of 2006 seadoo sportster 215hp
2006 sporster battery
Started by Mike0124, Jul 18 2010 12:13 PM
Posted 18 July 2010 - 12:13 PM
Posted 20 July 2010 - 11:56 AM
Mike you could try installing dual batteries, this has worked out well for many people - http://seadoosportbo...dual-batteries/
Posted 20 July 2010 - 01:28 PM
Mike, are you saying your battery only lasts three outings between charges? If so, and you're not running the stereo all day without the motor running, then seems like either your battery's reached the end of its life or your rectifier/regulator is beat. If the battery is original to the boat then I'd replace it. You might also hunt for any drains on your system when powered down: for instance the bilge pump will run even with the main power switch in the "off" position. In any case it's not normal for the battery to die between outings.
Dave
Posted 13 September 2011 - 12:04 PM
My 95 isn't charging the battery at all (per boat mechanic)either. I stopped him from going any further since it would all be trouble shooting and the meter was running. Anybody else had this problem? Is there a simple fix?
