09 seadoo speedster intake grate problem
Posted 20 June 2010 - 07:54 PM
Posted 21 June 2010 - 06:59 AM
Posted 21 June 2010 - 08:55 PM
Posted 22 June 2010 - 07:16 AM
Posted 22 June 2010 - 07:03 PM
Well I am glad you were finally able to get the grate removed, please keep us posted of what modifications you make to improve the accessibility in the future.
yes so am I>>>>it was a pain to get the broken bolt out but its fixed now...what i was thinking was installing a 40-50 mm stud with nut on top under motor then jb weld and silicon it to the boat (since i cant touch it with my hand to fiberglassthe nut to the hull) then using a nut on the other side so that you can get the grate off with ease buy just removing 3 10mm bolts and one nut..
im glad i sucked up the stick at idle of i would have messed up the wear ring for sure and possibly impeller
Posted 27 July 2010 - 11:47 AM
This is helpful info as I attempt it this week. How did the redesign turn out?
Posted 02 August 2010 - 12:19 PM
You cant really use an extractor because there is a lock nut inside the hull under the engine where it is almost impossible to access with supercharged engines. So you have to remove the lock nut, or else try drilling out the whole bolt and using a thread chaser or heli coil to repair the threads.
I tried to slot the bolt and turn it INTO the hull no luck the slot broke
Runnin without grate now (which I did for 10 years with my 95 Speedster no probalems)
Bad design.
Posted 10 August 2010 - 06:24 PM
I had this same thing happen to me on Sunday. I simply can't believe they designed the bolt to not easily be extracted to the point you break the head of it off.
yes it is very very stupid design but you can get to the nut under motor it is dificult but it can be done since i did it...you have to dig silicon off of the nut to put a wrnech on it the easy out the borken bolt..
my new design hasnt been down yet since im still using the boat but it will work for sure..just need a 8.x1.25 stud 45-50mm long glue or silicon it in and install a nut on top and a lock washer and nut on bottom of grate done
Posted 10 August 2010 - 11:54 PM
How many others run without a grate?
Posted 04 November 2010 - 08:19 PM
Posted 04 November 2010 - 08:21 PM
