Grade of Gas
Posted 07 June 2004 - 10:12 AM
Posted 07 June 2004 - 10:21 AM
http://seadoosportbo...com/merc/1b.pdf
Posted 07 June 2004 - 10:27 AM
I have had a tank or 2 of "bad" gas using regular in the past. Not in the boat, but in the truck. Runs like crap, sputters...etc etc.... Depends on who's Gas it is....
Posted 07 June 2004 - 10:35 AM
Guest_greggebhardt_*
Posted 06 July 2004 - 05:58 PM
From what I did read, mid grade provide the octane reguired.What grade of gas does everyone run in their 240 EFI, I ran regular all last summer because I have never heard any different? Should I be running premium? Is there any literature that states what we should be running in this motor?
Posted 20 July 2004 - 07:33 AM
i use 87 octaneFrom what I did read, mid grade provide the octane reguired.What grade of gas does everyone run in their 240 EFI, I ran regular all last summer because I have never heard any different? Should I be running premium? Is there any literature that states what we should be running in this motor?
Posted 27 July 2004 - 10:25 PM
Posted 28 July 2004 - 05:52 AM
Posted 26 August 2004 - 01:56 PM
I don't know how much everyone knows about octane, so I will tell you briefly what it means pertaining to what octane you should use in your engine. Fuel with a lower octane rating has actually more heat energy, or BTU's in it. Heat energy is what pushes your piston down and gives you power so it would seem that less octane is better. Yes, but lower octane fuels are less stable and burn with more of a bang than a controlled burn you would get with a higher octane fuel. This is where preignition (pinging, spark-knock etc.) come in. So as the octane level of the fuel goes up, the fuel has a more controlled, slow complete burn, but with less overall BTU's.
That is why high performance race engines with very high compression must use very high octane fuel. The fuel must be stable enough not to ignite under the intense heat of compression. (My dad's drag racing snowmobile has to use minimum 112 octane fuel to keep from burning pistons)
On the other side of that, my Suzuki Hayabusa GSX1300R motorcycle calls for 87 octane fuel, and it makes 4 more horsepower with that than on 92 octane fuel (same brand). This was tested by me on a rear wheel dyno at a bike shop in my area.
So by this math, if Merc designed their engine and injection system to use 87 octane fuel, this is the fuel that you will get the most power with. The ony other thing to think about is that with mid grade or premium especially, you are buying the cleaning additives in the fuel as well as built in preignition protection. There are very few cleaning additives in regular fuel to keep your injection system clean, and if the fuel gets stale and loses an octane count or two, you could have some preignition and start to damage the tops of your pistons.
Hope that helps and doesn't confuse anyone worse! If anyone thinks I didn't make any sense, let me know and I will try to explain better.
Posted 26 August 2004 - 02:25 PM
Posted 26 August 2004 - 03:30 PM
Posted 27 August 2004 - 08:31 AM
