Trying to compare boats and see what I want to buy. Looking to compare the sea-doo jet boat models to i/o prop boats. Four Winns posted all specs for there boats for every year, size, and motor hp, so I use them as a standard for i/o comparision. But can't find much on jet boats other than the typical "they suck fuel" comments without any real specs.
GPH specs for Sea-Doo boats?
Started by ryker, Jun 12 2009 06:31 AM
Posted 12 June 2009 - 06:31 AM
Posted 12 June 2009 - 07:26 AM
We have a '08 180 Challenger, I don't believe it "sucks" fuel...seems pretty average to me. It all depends on what you are doing; if we are cruising then the fuel goes farther but if we are doing watersports then obviously we go through it a lot quicker.
Have a look here to see if you can find the specs you are looking for, http://www.boattest....rch_result.aspx.
Posted 12 June 2009 - 10:58 AM
Out on our test run the Utopia 185 ran at 45 mph at wide-open throttle, and her best cruise was 24.6 mph at 4000 rpm. At this speed the Utopia has a cruising range of 164 miles with a single fill of the 40-gallon fuel tank.
If my math is correct thats 6 gph.
164 total miles / 24.6 mph = 6.66 hours untill empty on the 40 gallon tank
40 / 6.66= 6.0 gph
From what I've read about on other boats I would doubt that 6.0 gph. 6 gph is really low for a v6 2 stroke outboard motor much less a jetboat.
"The Challenger 20' has 20 degrees of deadrise at the transom, which gives you the best ride possible in chop. We measured a quick hole-shot of 1.9 seconds to be exact. Its 2,100 lbs. is heavy enough for breaking through waves, but it doesn’t hold the boat back. In fact, this boat hit a top speed of 49.9 mph at 5650 rpm and her optimum cruise was at 27.6 mph at 4000 rpm. This all adds up to 109 miles of fun at best cruising speed."
109 total miles / 27.6mph = 3.9hrs
40gallon tank / 3.9hrs = 10 gph
