engine quits suddenly
Posted 09 June 2008 - 02:18 PM
- Anjaaperype, AntoineJaky, Allysonmolo and 1 other like this
Posted 12 June 2008 - 09:59 AM
Posted 12 June 2008 - 01:23 PM
Posted 07 July 2008 - 01:54 PM
Report back!
Posted 26 August 2008 - 08:11 PM
My problem only happens at near to wide open throttle, below 40MPH I can run all day.
I'll also try what WAJetboating suggested when I get the boat back in the lake later this week. From my expierence it's like someone turned off the key - RPMs drop right to zero, starts right back up.
What/where is this relay you talked about?
Since this post was starting in June - what happened? Did you find the problem? share please if you did.
Posted 27 August 2008 - 12:49 PM
Wish I had a suggestion, instead I have what sounds to be the same issue. (2001 Challenger 1800, 240HP M2 EFI).
At the risk of long distance diagnostics these symptoms sometimes occur because the ground from the engine to the battery is corroded. The engine gets hot and causes the ground to break, after it cools it miraculously fixes itself. Check the ground where it attaches to the engine from the battery. Even if it isn't loose clean it up anyway. Also make sure the battery posts are not loose on the battery. Did you have the throttle recall done?
Posted 29 August 2008 - 08:40 PM
Thanks for the suggestion - another thing to check. I understand the 'long distance diagnotics' part it's my issue to solve, just looking for ideas like your - thanks.
It's wierd that it starts right up again after it dies, no sputtering just turns off by itself. I think it has to be electrical. It may be some type of 'relay' (as mentioned earlier in the thread) that at high speed (and high RPMs) trips from an overload of some sort.
Had it out today and had it up to 50+ for a short time 20 seconds without a problem, crusied at 40+ for several minutes...
RIght now I'm living with it and checking ideas as they come up.
Send more ideas if you have any
Jim
Posted 30 August 2008 - 01:16 PM
Send more ideas if you have any![]()
Jim
Jim, one other thing to check is the primary fuel pump on the engine. Trace the fuel inlet hose to the first pump it comes to. Carefully see if there is fuel flow through it.
Posted 01 September 2008 - 10:57 AM
I've now missed the best time of the summer to use the boat. It's now been out of commission for nearly eight weeks. After this repair, the boat will probably go up for sale. I bought the boat last June. According to the mechanic at that time it was in excellent condition. After the first weekend of use, I spend over $2,000 repairing the jet-drive after a tine off the intake grate sucked through the jet. Now this. I'll never buy another Mercury product and wouldn't recommend one to anyone.
Any advice would be welcomed!
Posted 01 September 2008 - 04:23 PM
Utpoia Bill: Man that story stinks. It sounded like you found the issue but your repair place didn;t chase that lead... odd. I need to get an engine manual on this beast. Interesting that there is a low pressure fuel pump.
SO much to learn. I've living with the issue as it only happend when you run over 5500 RPM for a while, so I just crusie about at 40-45mph and avoid the issue. Thanks for the info.
Posted 03 September 2008 - 04:44 PM
keviseeb: There is fuel in the line. If it was a gas issue would it studder and die not just quit like someone turned off the key?
This is a good one....here are some possibilities suggested by a Tecnical Rep at Mercury Marine not in order of importance:
1) The alternator is weak and at higher RPM the battery draw is such that the electronics are shutting down.
2) The primary fuel pump is weak and at 5,500 RPM the engine starves and dies, this happens more with Optimax engines but is possible with the 240 EFI since they use the same basic block. It DOES tend to happen suddenly.
3) Back pressure in the exhaust will cause these symptoms as well. We have found the exhaust line collapsed at about that RPM if the earlier recall had not been done or wasn't done right. This is the recall done on all 2004 and earlier Merc engines.
We aren't a big fan of the Mercury either, they seem to work better in a Sugar Sand once you replace the primary fuel pump and fix the exhaust on the Optimax models. They were a necessary stepping stone in the evolution to the current design, we have some customers who bought 2000 models now with 700 hours and have never done anything but routine maintenance! Let us know if any of the things above make sense or work if you try them.
Posted 06 September 2008 - 02:54 PM
Interesting ideas. Last Monday my son had it out and it quit again (he said not at full speed) and it would no longer start but the starter would not kick in (just a quiet relay click you have to really listen for), they had to be towed off the lake
Thanks for the info and ideas - I'll post what the shop finds.
Posted 09 September 2008 - 05:38 PM
The starter issue was a ground wire that had vibrated loose. They actaully said it was their fault - no charge. The high speed die problem, they say it was a spark plug boot that was almost off. They said that is the spark monitor system senses an 'Arc' (at high speed , high amp operation) then it would shut down the engine.
They tested the boat on a local lake an ran for 'over 5 minutes' at wide open throttle with no issues.
(I could not get more than a minute out of it before it died)
So - check your plug wires
Thanks for the ideas and support everyone.
Jim
#14
Posted 01 August 2009 - 12:30 AM
excellent, I have same problem. I will check plug boots tomorrow and see if that helps mine.
#15
Posted 01 August 2009 - 09:36 PM
Seems to be a problem that is made worse in rough water. Guess I will check all the electrical connections and wiring.
I'm starting a new post as this one has status moved.
http://seadoosportbo...-off-t2342.html
#16
Posted 20 September 2016 - 10:19 AM
Problem is circuit board mounted within the engine the compartment on the wall behind seats, The problem confirmed buy SEA DOO factory. Sold state relays on board malfunctioning.
Sea Doo factory sold me the last board they had, installed it and boat runs perfectly. Sea Doo enginerring as well as the dealer recommended I get rid of the boat because there is no repair for the board or other spare parts for the boat anymore.
So I sold the boat, it was in absolute mint condition. The Boat sold Immediately.
My Sea Doo nightmares are over.
- Boatlover likes this
#17
Posted 16 March 2017 - 08:24 AM
#18
Posted 22 March 2017 - 10:06 AM
Just read this review. Going to purchase 2001 Utopia, should i reconsider???
Thanks!
#19
Posted 10 November 2025 - 08:14 AM
Cheats in video games are illegal software used to exploit game mechanics, giving players an unjust benefit. In the context of Counter-Strike: Global Offensive (CSGO), cheats typically involve features like aimbots, wallhacks, or recoil control, which improve player performance beyond normal human ability.
Within the CSGO cosmetic betting sector, cheats are especially influential. This industry revolves around betting using in-game skinsâcosmetic items that have real-world value. Cheats can influence the outcome of matches or gambling games by allowing users to predict results or by automating betting processes.
Cheating software operates by injecting code into the game client or external applications, intercepting game data, and modifying it to display information hidden from regular players. For skin gambling, this could mean bots placing manipulated stakes based on in-game events or manipulating game outcomes to maximize profits illegally
Despite efforts by game developers and http://www.hallettfu...wrong_code=true gambling platforms to identify and ban cheats, the market remains vulnerable due to the clandestine operation of cheat distribution and usage. This creates significant challenges regarding fairness, player trust, and legal implications within the combined space of CSGO gameplay and skin gambling.
In summary, cheats in games like CS:GO are illegal tools that manipulate game functions. When these cheats intersect with the skin gambling sector, they enable fraudulent behavior, undermining the integrity of both gaming and betting environments.
Key synonyms used in this article:
- Cheats: illegal software
- Games: digital entertainment
- Skin gambling: virtual item wagering
- Affect: manipulate
- Operate: operate by
- Market: realm
