Battery issue
Started by kevin mc, Jul 02 2007 03:29 PM
Posted 02 July 2007 - 03:29 PM
It seems like im possibly having a problem with my battery or my charging of it when my boat is in use.....Is there a way a can check to see if my battery is getting charged while i am using my boat...???? (1999 sea doo challenger 1800)
Posted 15 July 2007 - 12:28 AM
You can install a voltmeter, an ampmeter, or maybe temporarily wire a digital multimeter to the battery. If you are charging properly, you should read about 13.7 volts when under way. Some people prefer the ampmeter which reads net current in/out of the battery - zero is in the middle. When you are charging, the needle should be pointing somewhere in the plus side.It seems like im possibly having a problem with my battery or my charging of it when my boat is in use.....Is there a way a can check to see if my battery is getting charged while i am using my boat...???? (1999 sea doo challenger 1800)
