This Safety Recall is being conducted in cooperation with the U.S. Coast Guard, which will monitor its effectiveness, and Transport Canada, in Canada.
What is the reason for this notice?
In cooperation with Transport Canada and the U.S. Coast Guard, Bombardier Recreational Products Inc. and BRP US Inc. ("BRP") are conducting a voluntary safety recall of all Sea-Doo sport boats equipped with ROTAX naturally aspirated, 155 hp, 4-TEC engine, model year 2003 to 2007, as specified in the attached Safety Campaign Bulletin. Our records indicate that you are the owner of a potentially affected vehicle.
What is the potential problem?
Some pieces of the air box may detach. This may allow broken pieces to be drawn to the throttle body and in some cases, could prevent the throttle plate from returning completely to idle position, potentially leading to an unexpected failure to decelerate when the throttle lever is returned to the idle position. This situation could cause a collision with bystanders, a fixed object or another vehicle and potentially cause serious injuries or even death.
What should you do?
Immediately stop using your vehicle, call an authorized BRP dealer and make an appointment to have your vehicle repaired. The dealer will perform this work at no charge to you.
What to do if you feel this notice is an error?
This notice was mailed to you according to the most current information we have available. If you no longer own this vehicle or some information in this notice is incorrect, please contact BRP at your earliest convenience.
Safety Recall Notice Letter
Model & Serial NumbersIf you have questions, need assistance, or to find your nearest authorized BRP dealer:
Visit www.seadoo.com
In the US and Canada: 1-888-864-2002, 8:00 to 18:00 eastern time
We apologize for any inconvenience this may cause you. Thank you for your immediate attention to this matter.
Sincerely,
After Sales Service Department
™, ® trademarks of Bombardier Recreational Products Inc. or its affiliates.
www.brp.com
Source: SeaDoo
