fuel gauge
Posted 03 June 2007 - 12:55 PM
Fuel gauge stop working during first run this year.
How do I check the fuel gauge & fuel tank senor ?
Three wires to fuel tank show no continuity through any combination.
Voltage a the meter --purple 11.8v, pink & pink-blk 5.7 & drops to 4.9.
Which meter wires can I use the check operation & what voltage.
Does any one have a schematic ?
Thanks in advance
Posted 03 June 2007 - 09:19 PM
Posted 04 June 2007 - 04:57 PM
Thanks,Check out my post here, http://seadoosportbo...?showtopic=1580, I had the same problem this season.
talked to a dealer & confirmed that 99.9% of the problems are with the sensor.
What he did is that the rubber hose connections could be in different locations, but they are marked.
He also said many times the hoese can be pulled right off with the clamp & then put back on.
Posted 12 June 2007 - 12:03 PM
my fuel sender has 4 hose connections on top and a 3 wire connector (not 2 wire) so according to one post --problem solving we should jump the pink with the pink/black wire to check if the fuel gauge work,,, if the gauge work then that suggest the sender is the problem,,is that correct?Thanks,Check out my post here, http://seadoosportbo...?showtopic=1580, I had the same problem this season.
the post from kevin,addresses the 4 hoses and I know that at least two of the 4 slip on connectors on the top of the sender unit are labeled,,but which hose to goes to which (from where to where) so we know the hoses are not crossed, Kevin's dealer person suggest that miss matching the hose connections can cause the sender not to work properly.
Posted 12 June 2007 - 06:20 PM
II jumped the piink wire to the pink/black strip wire using a test light (alligator clip to one and ice pick nose/strobe to the other wire ) and the gauge registered full or near full. So according to this test, the gauge does work,,, so my poblem could very well be the sender unit or the 4 noses on top are not connected correctlyThanks,Check out my post here, http://seadoosportbo...?showtopic=1580, I had the same problem this season.
Posted 27 June 2007 - 07:06 AM
Posted 15 July 2007 - 12:12 AM
Tank Sender provides a resistance between approximately 0 ohms (full tank) and 90 ohms (near empty tank) to the guage. So if you disconnect the two wire connector from the tank sender, you can perform several tests:
1 - using a digital ohm meter, connect meter leads to the sender part of the connector. If you get anything higher than 100 ohms, the sender is bad (most common problem). I have fixed several of these, but believe me it is almost not worth it.
2- using a varable 100 ohm resistor (potentiometer) otherwise known as an old volume control from an old radio, etc. (Try to find one near 100 ohms). You will connect this to the boat's side of the two wire connector. Now activate your boat's electrical system by pressing the start button (will be active for approx 30 seconds), if your fuel gauge is good, you will be able to move the needle by turning the pot.... really nifty!!
I actually made a gauge tester for a sea doo mechanic by soldering a spare connector he had to a potentiometer.
Posted 26 May 2010 - 05:30 PM
Thanks!
-Chris
Posted 27 May 2010 - 04:41 AM
Posted 29 June 2010 - 10:43 AM
I replaced the float on mine this winter,$14.95 works fine now. They tend to lose the magnets, was missing 1 of 4,wouldn`t read fuel level.
Posted 29 June 2010 - 07:26 PM
Posted 06 July 2010 - 11:12 AM
-Chris
Posted 06 July 2010 - 02:25 PM
#14
Posted 11 July 2010 - 03:13 PM
#15
Posted 03 July 2011 - 09:10 PM
#16
Posted 04 July 2011 - 08:12 AM
