Starter problems
Posted 08 April 2007 - 07:05 PM
I am having starter problems.
Firstly a little back ground - I have a 2004 Sportster LEDI with a 2 stroke Rotax 947.
Just recently one of the (cheap plastic) "T" connectors that connect 4 major tubes in the water cooling system busted and the engine started to heat and blah blah blah... lots of damage.... Everything is back to par with the exception to the starter. Water got in the crank case and was vacummed out using special intruments. Then was flushed with carberator cleaner and then with oil. I have perfect compression in the piston chamber. So the crank case is AOK. There is zero water in the crank case. I have run it since the cooling issue and flooded crank case issue and the engine purred like a kitten! --- it ran perfectly.
NOW the starter will not work.
When I attempted to start the engine on the first occasion all that happened was the starter was spinning and the crank shaft would not turn. So I went on a forum and read that some guys who were de-winterizing there sportboats would have to remove the spark plugs and rotate the shaft with their hand a little and then start it. Well I did exactly that and it worked!!!! I have done that on every occasion since and now..... And now that method doesn't work anymore.
I have tried to remove the starter by removing the two screws and pulling and tugging on the thing without sucess. I didn't want to force anything. I was thinking if I get my starter out I can shoot some WD-40 in where the "bendix" resides and perhaps get everything going.... Not sure.
I'm thinking there is something maybe the "bendix" is seized or has some seizing going on... I have no clue. It could be an electrical problem that is causing the spinning starter not to turn the flywheel so my boat starts. Can someone help! I need to know what I should check given my current situation. There is not a seadoo shop within 500 miles of where I am located.
Many Thanks.
Nick
Posted 08 April 2007 - 09:23 PM
If the starter spins but doesn't engage the flywheel, then chances are a seized bendix is your issue. It is centrifugal, and has no choice but fly out and engage- unless it has become rusted on the starter shaft.Hello All!
Many Thanks.
Nick
Check the rear of the starter for a bracket bolted to the block, and remove it- the starter should fall off in your hand. Of course, be sure you have disconnected the battery first.
You should be able to spin the bendix one way or the other and see that it spins out on the starter shaft. If it doesn't do it either way you turn it, then it has rusted to the shaft. A few firm taps with a hammer will break it loose in most cases. it will still need a little cleaning and lube if this does it, or it will continue to rust and do this again next season. Disassembly is simple, provided you have the correct tools. DON"T TAKE THE STARTER MOTOR APART UNLESS YOU KNOW WHAT YOU ARE DOING- they are difficult to reassemble because of the brushes. I think you may find that the bendix is the issue, though.
Posted 09 April 2007 - 12:24 AM
Tigger - thanks for replying so quickly! Youre the best!If the starter spins but doesn't engage the flywheel, then chances are a seized bendix is your issue. It is centrifugal, and has no choice but fly out and engage- unless it has become rusted on the starter shaft.Hello All!
Many Thanks.
Nick
Question: I need to get to the bendix. However I spent an hour staring at the starter and surrounding parts.... feeling around for a way to get to the bendix without luck. When you say "bracket" at the rear of the starter... are you referring to the bracket holding the starter together? Because I do not think I need to take apart the starter. I'm just trying to get the the bendix like you said. I haven't a clue how to get to the bendix. I did remove the two bolts at the bottom of the starter that hold it to the block , however I tugged and tugged for an hour and could not budge the starter. I have attached a diagram for better understanding of what's going on. Thanks so much for your help!
Posted 09 April 2007 - 06:46 PM
If you look at this diagram ( it is an XP DI, but its the same engine), part number 18 is your bendix- somewhat different than mine, but it works by the same principle.
http://216.37.204.20...pe=13&A=115&B=2
It is probably going to come out the front of the engine, and the magneto cover may have to come off. It looks like it has a smaller cover there as well. Reminds me of a Polaris the way the bendix is separate from the start motor.
You should probably purchase a service manual, available on eBay, for a further breakdown of how toget this part out for inspection.
Posted 10 April 2007 - 09:49 AM
Tiggerman - My biggest problem at this point is that I have take the 2 screws out and have tugged for an hour at the thing and cannot pull it back. It doesnt make sense that you would have to take the whole engine apart to get the stinkin starter off. Do you know anyone who has removed a starter from this type of setup? If so... is it difficult to remove? Thanks for all your help!Your diagram makes sense- I wasn't paying attention that it was a 947. The 2 bolts you removed should let the starter slide back. You're right in not taking the starter apart.
Nick
Posted 25 March 2011 - 08:54 AM
