question about oil
Posted 24 April 2004 - 10:12 AM
Posted 24 April 2004 - 12:17 PM
btw i have amsoil in there now and i dont know if it is synthetic...
Posted 24 April 2004 - 05:42 PM
So I can't say with authority if the 2 will play well together.
Posted 24 April 2004 - 07:47 PM
Well tomorrow morning I will look at the oil tank and see if I think I need to add any oil....How low should I let it get before I should add any? Right now it is right below the halfway area of the tank...Maybe I should wait till it gets lower? i CAN'T WAIT TO GET OUT ON THE WATER!!!!!!!!!!!!!!!!!I doo believe the Amsoil is a synthetic. You probably could run the tank really low and then pour in some fresh Bombardier oil, minimizing the mixing of the two. I don't like to mix. You could also drain the tank and lines and refill with fresh Bombardier.....which ever you're comfortable with. I'm not an oil-ologist
Posted 24 April 2004 - 08:49 PM
Go ahead and top it off and take it out tomorrow, man! We went today, and it was a perfect day for it. Water was a little warmer than last weekend (warmest I found today was 75) but not quite warm enough to be comfortable..
Posted 26 April 2004 - 08:07 PM
Yes, the Amsoil is synthetic.
Posted 26 April 2004 - 08:13 PM
Posted 26 April 2004 - 08:58 PM
10 bucks a gallon? Yikes. If you make it through the year, let me know, and I will try it...next year.
Posted 27 April 2004 - 06:01 AM
Posted 27 April 2004 - 03:52 PM
The Amsoil is synthetic. I run that in the SPX that I own. It is a bit costly. Just received four (4) one gallon bottles from Amsoil for $75.00, so just under $20.00 per gallon.
Posted 27 April 2004 - 08:38 PM
The Citgo is a synthetic blend, and one of the few that doo meet the specs that Seadoo calls for on these engines. My boat specifically states 'do not use NMMA TC-W3 oils'. That eliminates most outboard 2 stroke oils. This is from the Citgo website:
SUPERGARD® Sea and SnowTM is formulated primarily for use in high performance air-cooled or liquid two-stroke engines of Personal Water Craft (PWC) and Snowmobiles. It can be used in motorcycles, generators, lawnmowers, and hand held power equipment such as leaf blowers, trimmers, and chainsaws. SUPERGARD® Sea and SnowTM provides the necessary protection to keep your snowmobile or PWC running cleaner, longer, and with less smoke.
And this:
In addition, SUPERGARD® Two-Cycle Engine Oil is a synthetic blend which reduces exhaust smoke and prevents piston seizure and cylinder scuffing. SUPERGARD® 2-Cycle Engine Oil is prediluted to allow easy mixing with gasoline and smooth flowing in oil injection systems. CITGO SUPERGARD® 2-Cycle Engine Oil can be used in either premix or oil injection systems up to 50:1 fuel to oil ratios. Not recommended for engines requiring an NMMA TC-W3, TC-WII, or TC-W product.
My impression: Any low ash type oils like the ones that are rated API-TC, ISO-EGD, and JASO-FC will work fine in my engine. This includes the Citgo. Besides, I can afford it and it is plentiful. We could debate oil forever, but others already have. It all boils down to preference. And cost in my case.
Posted 28 April 2004 - 05:10 PM
I am not debating oil, it just seems like a very low cost to me, and for what little oil that I use, I will continue to use what has been working for me.
Now if you can find a low price on gas, I'll try it.
Posted 28 April 2004 - 08:25 PM
I see Kevin has several oil links up top....
#14
Posted 29 April 2004 - 04:41 PM
Says on the back that it in all oil injected PWCs, snow mobiles etc...
Does anyone know any different?
and what does NMMA stand for?
#15
Posted 29 April 2004 - 04:58 PM
