please can anyone help.....on going problem,boat stalls repeatedly after initial start. also after a period of hot soak.(letting sit for approx 2 hours)boat will start perfectly ,but have no throttle response and quickly stall.the only way i have found to keep boat running is to keep ign switch held to the start position. you can only imagine how difficult this is to manuver in tight areas.....has anyone seen this? dealer has replaced tps,head temp sensor, cleaned fuel injectors/spark plugs and disabled shift interupter. thanks for any help
running problem please help
Started by diverupsidedown, May 29 2006 11:28 PM
Posted 29 May 2006 - 11:28 PM
Posted 01 June 2006 - 04:28 AM
not being an engineer but that sounds like it might be an ingintion/breaker type problem??
if you need to keep the ignition switch over to keep the engine running surely that will damage your starter?????
sorry if thats not much help
