Bent Post
Posted 27 May 2006 - 05:06 PM
Thanks, Kev
Posted 29 May 2006 - 09:06 AM
I have the same problem with my speedster. I figured out the hard way not to pull tubes with the ski pole. To fix it here's what i did. Mine only had a slight bend so i took the pole out and put a light coat of paint on it. I put it back in and moved it up and down a few times (it isn't fun) and took it back out. The paint should be worn off of the high spot on the bend. I put a sanding disc in my die grinder and worked it down in that spot. It takes a little trial and error but it solved my problems anyway.Recently purchase an airhead mega slice tube, and an airhead 4 person bungie rope to tow behind my 06 speedster. Well, the boat towed it great but when I went to push the ski post back down I couldn't. It was very slightly bent causing it not to go down. I was wondering if anyone else has had this problem. I had one adult, and two very small children on the tube. I think it was the bungie rope that caused it to bend because I could fell it surging and pulling on the boat. If anyone else has had this problem let me know. Guess I will figure out how to take the post off now.
Thanks, Kev
Good luck!
Nick
Posted 29 May 2006 - 04:25 PM
Posted 29 May 2006 - 07:18 PM
Posted 29 May 2006 - 07:47 PM
