when the challenger is left in the water overnight, it starts to take on a bit of water, causing the bilge to come on to empty it. is there a fix for this? thanks
taking on some water
Started by zhawg, May 10 2006 08:00 PM
Posted 10 May 2006 - 08:00 PM
I just purchased a 2000 challenger 1800 with twin 720 roatax engines, 2 x 85 hp.
Posted 11 May 2006 - 04:19 AM
there are a number of reasons for this - i assume there are no obvious holes in the hull below the water line?
the drive shaft seal may be leaking - or the drain plug 'o' rings may be missing -
check inside engine compartment next time its on the water - the leak may be so small to see with just a cursory glance but you didnt specify
two further things - the bilge pump if running for a long time will obviously stop your boat from filling completely and damaging engine and electronic components - they also drain batteries!
best solution - keep it on the trailer if you can - if you cant or dont want too - id the leak and get a dealer to fix it if you cant do it yourself
DO NOT RELY ON YOUR BILGE PUMP TO EMPTY YOUR BILGE - THEY OPERATE VIA A FLOAT SWITCH AND ARE NOTORIOUS FOR GETTING DIRT FROM THE BILGE INSIDE THE SWITCH AND NOT SWITCHING ON.
Posted 20 May 2006 - 12:48 PM
Jet-Boats should not be stored in the water while not in use; especially for days on end.
