[How-To] VHF radio installation
Started by tda3, Apr 30 2006 08:27 PM
8 replies to this topic
Posted 30 April 2006 - 08:27 PM
Just wanted to give a little run down to my installation of a fixed base VHF radio. The unit I chose was a Uniden Oceanus as you can see here.
Posted 30 April 2006 - 08:30 PM
As many of you know, Sea-Doo's are NOT known for very many flat surfaces so it was a bit tricky finding one to accomodate my antenna mount. The mount I used is a so-called ratchet unit. To the right of the mount is the co-ax feed-through.
Posted 30 April 2006 - 08:31 PM
This is what it looks like in the up position.
Posted 30 April 2006 - 08:35 PM
And here's what it looks like laid down when trailering or when a nasty storm comes up. These things make a very good lightning rod. Keep that in mind should a storm come up. The antenna I used is a Shakespear Galaxy 48".
Posted 30 April 2006 - 08:39 PM
Since I knew I was going to need power for both the AM/FM/CD radio and the VHF radio, I decided to install a fuse panel. This allows me to use common automotive style fuses and makes hooking up easier. You'll also notice that I'm using a Shakespear splitter that allows me to use the VHF antenna for both the AM/FM/CD radio and the VHF radio.
Posted 30 April 2006 - 08:44 PM
This shows the wiring for both the AM/FM/CD radio and the VHF radio. I drilled a hole for the power and co-ax using a Uni-Bit or step drill. These things are pricy as hell, but man do they ever do the job when drilling large diameter holes in fiberglass or plastic. And they make a very clean hole. I used a grommet to prevent chaffing.
Posted 30 April 2006 - 08:47 PM
Here's what the wiring looks like where it comes out. The four holes you see on the underside are the holes for VHF radio's mounting bracket.
Posted 30 April 2006 - 08:51 PM
And here's what it looks like with the VHF in place. The radio has a waterproof power connector so removing the radio from the boat is a snap. Just disconnect the power, undo the co-ax, loosen the two knobs, and it's out of there.
Oh - and yes, I know my boat is dirty.
Posted 01 May 2006 - 08:27 AM
Very nice!
