I wanted to make a shorter, more to-the-point post about the issue I am having.
2007 150 speedster (only used in intercoastal salt water) is getting water in the cylinders ONLY when it is off and floating in water. What would cause water to flow into the cylinders this way? Again, if it i running, no problem. If it is on land, no problem. BUT if it is off AND floating in water, water gets into the cylinders. It has dies on us now 3 times in the past 2 weeks when we take it to a sand bar.
Any guesses? Thanks a bunch guys!
